How do I join the corner of these two curtain wall sections that were cut out of exterior wall?
3 ANTWORTEN 3
Nachricht 1 von 4
daniel.kormos01
221 Aufrufe, 3 Antworten
Hello, if you look at the photo you can see what I mean. The curtain wall was placed inside of the exterior wall and then cut out of the wall using the cut geometry tool. I would like the corners of the curtain wall sections to join seamlessly.
Thank you!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: daniel.kormos01
Fillet the two curtain walls. Then use a void or opening to clean the corner of the brick walls.
Nachricht 3 von 4
daniel.kormos01
als Antwort auf: ToanDN
What do you mean by Fillet?
Nachricht 4 von 4
Fillet tool on Modify ribbon.
