Area Schedules with Shared Parameters
2 ANTWORTEN 2
Nachricht 1 von 3
benD3YH4
223 Aufrufe, 2 Antworten
Hi, I have a gross area schedule created to demonstrate apartment areas for a project. I'm wanting to add other parameters to this schedule that have been created and populated as shared parameters, for example apartment type and number. When I add these parameters to the Gross Area schedule the columns show but remains unpopulated, any ideas on this would be appreciated.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: benD3YH4
Is your schedule unitemized? Maybe share some screenshots showing an area properties with populated parameters on area plan, then the same area with unpopulated parameters in the schedule.
Nachricht 3 von 3
benD3YH4
als Antwort auf: ToanDN
Hi, no, its set to show every instance.
I resolved the issue by exporting multiple schedules to Excel and piecing them together there.
The project shared parameters are added to the Area schedule and will show up in the schedule, however they are associated to the Area now and need repopulating. I was expecting them as project parameters to retain the information already assigned to them when assigned to rooms, however I now realise the two entities are not linked, so I'd have to do imput the info all over again, which is why I did it Excel.
