Weird grey patch in all imported CAD files
wisedrawing
Message 1 of 9
wisedrawing
Has anyone seen this in their linked CAD files, it does not matter if I make the CAD file in my suite and import it, or if I use the surveyor CAD file (through mine to rescale) its always there. Obviously its not in the CAD file itself
Darren
Replies (8)
Message 2 of 9
Strange. Like a watermark. Let's have a look at it.  Post the DWG here.
Message 3 of 9
wisedrawing
dwg as export from the revit file back to CAD, I can't seem to select it, it does not appear in the original CAD file only when you link it to Revit and it only shows in revit and then now when I export from revit
Message 4 of 9
Explode and delete it.
It's a Hatch
Message 5 of 9
Message 6 of 9
wisedrawing
That does work but it means I have to load up once, export, explode and reload again? - its very strange
Message 7 of 9
I'm not totally following you, but if you don't want to get rid of it, then turn the Hatch Layer off.
...also "Object A" Layer.
Message 8 of 9
Message 9 of 9
wisedrawing
ha now we are talking
just FYI this is linked not imported so anything I needed to do to the file I have to do outside Revit, I also prefer not to import and explode CAD in Revit. So what I meant was that once I import the CAD then this grey showed up and you are correct if I export to CAD and then explode and then delete and then reload the link it actually does go away, but that seems long a long process for a little bug.
you last idea however fixes it and gave me another little skill for manipulating the linked CAD files
Darren
