Weekly New Knowledge Articles by Support team | Sep 22nd - 28th
lim.wendy
Alumni Alumni
Message 1 of 1
lim.wendy
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Article
Incident Reported
22-Sep-21
When working in Revit, opening certain views causes Revit to crash without any errors or warnings.
Crash with no warnings when opening specific views in Revit
No
24-Sep-21
When drawing a Tray in Revit, the error “The routing solution failed because there is no default fitting type specified…” appears.
“The routing solution failed because there is no default fitting type specified…” appears when drawi...
Yes
28-Sep-21
Add/Remove Wall to a wall sweep results in the "A serious error has occurred. It is strongly recommended that you use Save As to save your work in a new file before continuing" error for stacked walls.
"A serious error has occurred" when adding or removing a wall to a wall sweep
Yes
28-Sep-21
While working in a workshared Revit model, multiple views move off sheets unexpectedly.
Multiple views shift on Sheets in Revit
No
23-Sep-21
Users reported that after applying steel modifier for a structural member in Revit, the display is changed unexpectedly and this can not be undone, even after removing the modifier.
Changed display after applying steel modifier in Revit
Yes
24-Sep-21
Users reported that Fabrication elements in Revit projects do not display with the right fill pattern applied by a view filter override in floor plan views.
Fabrication parts unexpectedly show with solid fill paterns in Revit views
Yes
24-Sep-21
How to rotate an object to a specific angle during placement using the spacebar in Revit
How to rotate an object to a specific angle during placement in Revit
No
27-Sep-21
Users reported that some assemblies exported to IFC contain openings not assigned to these assemblies in Revit.
Some assemblies exported to IFC contain openings not assigned to these assemblies in Revit
Yes
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Replies (0)
