Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date |
Summary |
Knowledge Article |
Incident Logged |
26-Jul-22 |
Modifying Revit warning settings by adding custom entries in Revit.ini file does not work. |
Changing Revit settings by adding custom entries in Revit.ini file does not work |
No |
26-Jul-22 |
When synchronizing changes in a Cloud Worksharing host model in Revit, a linked point cloud unexpectedly shifts its position in the model space. |
Point cloud shifts position when synchronizing changes in a Cloud Worksharing host model in Revit |
No |
26-Jul-22 |
When using Place On Face option, some air terminal families in Revit rotate to align with the face, it is being placed on instead of being aligned with the view. |
Yes |
26-Jul-22 |
There is a parameter "FM-Geschoss" at most of the elements in German Revit projects. What does it mean? |
What does it mean the parameter "FM-Geschoss" in German Revit projects? |
No |
25-Jul-22 |
Users reported that shadows are incorrectly displayed in Revit views. |
Yes |
25-Jul-22 |
Linking the Revit model instance and assigning a project parameter to that link instance in the host model and creating a multi-category schedule to report the parameter which is assigned to the link instance. |
Yes |
25-Jul-22 |
When the top of the wall is attached to the specific sloped floor, a small gap is visible between the elements in Revit. |
No |
23-Jul-22 |
When drawing a piping/ductwork system out of a equipment, the system automatically does not show the correct system in Revit. |
Piping/Ductwork automatically does not draw the correct system out of a equipment in Revit |
Yes |
23-Jul-22 |
The site plan in national coordinates is not displayed correctly in Revit |
No |
22-Jul-22 |
End Caps don't convert to Fabrication Parts in Revit |
No |
22-Jul-22 |
How to read the elevation of a window or door in relation to the Survey point in Revit. Sill height and head height are calculated in relation to the insertion level. |
How to read the elevation of a window or door in relation to the Survey point in Revit |
No |
22-Jul-22 |
The phase filter in the wall lists does not work, when upgrading a model in Revit. |
The phase filter in the schedules does not work when upgrading a model in Revit |
No |
22-Jul-22 |
Unable to tag a parameter from a linked Revit model |
No |
21-Jul-22 |
What issues may occur when using Revit in different language versions in one project? |
What difficulties may occur when using Revit in different language versions in one project |
No |
20-Jul-22 |
Changing a length parameter moves a furniture family containing a mirrored and rotated nested family away from its host in Revit. |
Yes |
20-Jul-22 |
The dormer opening tool does not cut the roof surface properly in the ridge area, the roof should be cut horizontally in this area in Revit. |
Yes |
20-Jul-22 |
How to display structural elements from the linked file on top of architectural elements in the Revit host file? |
No |
20-Jul-22 |
The appearance of the structural elements is not consistent with the plan view in Revit |
Inconsistent appearance of the structural elements in plan view in Revit |
Yes |
20-Jul-22 |
The room color fill , which is created via the color scheme, hides the hatchings from the floor slabs in the background in Revit 2023. This happens regardless of the fill pattern (solid or e.g. diagonal). In Revit 2022, the surface patterns of the floor slabs are always in the foreground. |
Room color fill hides the background fill from the Floor slab in Revit |
Yes |
19-Jul-22 |
"Constrains are not satisfied" message appears while rotating Reference Line when nested family is aligned to it in Revit. The rotation can be completed when the nested family is not aligned to the Reference Line. |
No |
