Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date |
Summary |
Knowledge Article |
Incident Logged |
15-Apr-22 |
How pipe insulation area and volume are calculated in Revit? |
No |
13-Apr-22 |
When changing the survey point elevation in Revit, the level measurement should change from 0' to the desire level, but changes to a scaled number. |
No |
14-Apr-22 |
Users reported that when printing sheets in Revit that contain views with non-rectangular crop regions, the view with the non-rectangular crop regions is printed, but none of the other views are output, and the titleblock is missing. |
Yes |
14-Apr-22 |
When syncing a model, Reloading Latest hangs and take a long time to finish in Revit. |
Reloading Latest hangs and take a long time to process when syncing in Revit |
Yes |
14-Apr-22 |
Title block families with a Label that has Date/Time Stamp or File Path parameter ignores custom Width Factor settings when loaded into the Revit project. |
Label with Date/Time Stamp or File Path parameter ignores custom Width Factor setting in Revit |
Yes |
14-Apr-22 |
User reported that filled region in family loses its transparency when loaded to project in Revit. |
Filled region in family loses its transparency when loaded to project in Revit |
Yes |
14-Apr-22 |
Room does not reach the external wall despite the lack of room bounding elements in Revit |
No |
19-Apr-22 |
How to automatically edit complex floor shape in Revit |
No |
13-Apr-22 |
Users reported unexpected display when activating hidden lines display for MEP elements in Revit. When changing |
Unexpected display when activating hidden lines display for MEP elements in Revit |
Yes |
16-Apr-22 |
The synchronization process stops at the Reload Latest stage for the specified Revit Cloud Workshared model |
No |
16-Apr-22 |
Impossible to add a new Omniclass number in Revit family. |
No |
19-Apr-22 |
Incorrect geocoordination of Revit models in Navisworks |
No |
19-Apr-22 |
What is the fastest and easiest way to convert elements saved in AVEVA PDSM to families in Revit? Are there any available best practices or tools to perform a migration for multiple catalogs containing pipe classes, parts, assemblies and machines for plant construction? |
How to convert elements saved in AVEVA PDMS to Revit families |
No |
19-Apr-22 |
When the Work Plane-Based parameter is checked in the family properties, the default placement method is still Place on Face rather Place on Work Plane after loading the family into the Revit project. |
Cannot insert Revit families with Place on Work Plane option selected as a default placement method |
No |
19-Apr-22 |
Users reported that slab edge elements always exported to IFC as IfcBuildingElementProxy from Revit. |
Slab edge elements always exported to IFC as IfcBuildingElementProxy from Revit |
Yes |
13-Apr-22 |
Type Selector drop-down stops responding for a specific family in the Revit model and the Esc key also stops working. |
Type Selector drop-down stops responding for a specific family in the Revit 2023 model |
No |
@lim.wendy - Is this an ongoing tool? Would love to know what to watch out for Revit and Desktop connector issues.
Thanks!
Ron
Digital Transformation Team - BIM and Data management
