Walls in print are in Gray ( I wish to make it all black in print)
10 REPLIES 10
Message 1 of 11
joyenrhenz_dabu
461 Views, 10 Replies
I am very new to revit and I have no idea why are my walls during printing are in gray tones, other walls are in black. Is there anything i can do to make all of my walls black?
10 REPLIES 10
Message 2 of 11
check your VG if there is assign Filter or post some screenshot here. thanks
Message 3 of 11
hi sorry i check the VG thing and I saw other post to have this setting (pic1), but my print are still like this
Message 4 of 11
are they the same type of wall?
Message 5 of 11
check here and see if helps?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Details-printing-g...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-Basic-printe...
Message 6 of 11
yes they are all in same type. can i send my plan here?
Message 7 of 11
can
Message 8 of 11
can sorry but im going off already i can reply you by tomorrow. wait others to reply. thanks
Message 9 of 11
Maybe Coarse Scale Fill Pattern?
Change View Detail Level to Medium or Fine, or remove Coarse Scale Fill Pattern under Wall Properties.
Message 10 of 11
...might also be a graphic override taking precedence over another if you have multiple overrides going on in the view. Maybe it's coming from the view's Phase Filter graphic override?
good info here:
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-67D3D6DB-E78D-4711-B9C3-4D30F1C22205
Message 11 of 11
It could be your printer options (see "Print Setup")
Forma Design Contest
Technology Administrators
