I am very new to revit and I have no idea why are my walls during printing are in gray tones, other walls are in black. Is there anything i can do to make all of my walls black?
Solved by anze.kumar. Go to Solution.
check your VG if there is assign Filter or post some screenshot here. thanks
hi sorry i check the VG thing and I saw other post to have this setting (pic1), but my print are still like this
are they the same type of wall?
check here and see if helps?
can sorry but im going off already i can reply you by tomorrow. wait others to reply. thanks
Maybe Coarse Scale Fill Pattern?
Change View Detail Level to Medium or Fine, or remove Coarse Scale Fill Pattern under Wall Properties.
...might also be a graphic override taking precedence over another if you have multiple overrides going on in the view. Maybe it's coming from the view's Phase Filter graphic override?
good info here:
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-67D3D6DB-E78D-4711-B9C3-4D30F1C22205
