WALLS AND FLOORS NOT SHOWING UP ON SECOND LEVEL FLOOR PLAN
cliftonmaggard
Message 1 of 10
cliftonmaggard
Im new to Revit and using Revit 2022.  The wall and floors that I created are not showing up on the second level floor plan. Although they show up on all other levels. Have tried adjusting view range,  but it didnt work.  Any ideas ?
Thanks CMaggard
Replies (9)
Message 2 of 10
Looks like the wall and floors are below Level 2.  Set your View Range Bottom and Depth to "Unlimited" and see if they become visible in the Level 2 View.
FWIW: Here's a good reference to keep handy for occasions just like this:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Message 3 of 10
PhilvK
Could be something as simple as you're not zoomed out far enough? Try Zoom Fit - ZF
Message 4 of 10
cliftonmaggard
Tried ZF and ZE it works on other level floor plans except Level 2.  I'm sure what ever it is is simple. Thanks CMaggard
Message 5 of 10
kjskoog
Might have an item on the second floor level that is way outside your plan. In your second floor view type ZE, then do a crossing (lower left to upper right) from the one corner to the other and see what is selected. If two areas have something selected then you have a wondering component.
Kory Skoog
PM/BIM Manager
Message 6 of 10
Show a screenshot of the rest of the view properties.
Message 7 of 10
mercylovegrace688
nothing worked....any other ideas?
Message 8 of 10
maurice.garlet
Community Visitor
Community Visitor
I am having the same problem. I have been designing a few models of small two-story homes and for some odd reason on the last project, nothing shows on the second floor. I already tried everything and nothing seems to work. The outside walls go all the way to the top of the second floor and even those don't show. I tried selecting a wall to see if something highlights on the second floor and nothing.
I created this last project exactly like the previous ones and none of them have this issue.
I will appreciate any suggestions.
Message 9 of 10
If none of the info in this thread is helping, then I would suggest posting your RVT file here and letting us examine it.  That's the quickest way to get an answer instead of guesses.
Do you know how to post your file here?  Start a reply post, scroll down to "Attachments" and press "Browse".
Message 10 of 10
clarkpmike
I had the same problem when starting a new project with the imperial construction template. The Phase on Level 1 is set to "Project Completion", meanwhile, the phase on Level 2 is set to "B10 Superstructure". To display the walls in this case, change the phase filter on level 2 or any other problem level to "Project Completion"
