1st Floor Walls are Not showing up on 2nd floor floorplan (level)
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
cliftonmaggard
565 Aufrufe, 5 Antworten
1st Floor Walls are Not showing up on 2nd floor floorplan (level). Have tried adjusting ranges ect nothing works. I'm new to Revit. Using Revit 2022.
Thanks CMaggard
5 ANTWORTEN 5
Nachricht 2 von 6
cliftonmaggard
als Antwort auf: cliftonmaggard
ADDITIONAL PROPERTY SHOTS
Nachricht 3 von 6
Check the Phase of the view and make sure it matches other (showing correctly) view.
Nachricht 4 von 6
RDAOU
..  didn't see previous reply
Nachricht 5 von 6
cliftonmaggard
als Antwort auf: ToanDN
This was the problem,  "PHASING " settings.  I have no idea what Phase means at this point. How did this get set different,  I have no idea. You are the man Thanks !!!!!!
Nachricht 6 von 6
cliftonmaggard
als Antwort auf: RDAOU
You nailed it!!  that was the problem.  How this got set different I have no idea.  THANKS !!!!
