Walls & hatch patterns
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
I am having problems with walls & hatch patterns. I am confused as to why this is so difficult. I have two walls adjacent to each other, one is a brick wainscot & the other is full height brick.
On the end of the wall the hatch pattern does not show -on either end of the full height wall – why not? Is it because it butting up to the wainscot wall? Why is it solid then, no hatch.
How do you make this look correctly? It does in realistic visual style....
Also, I get a line showing at the coursing where the two walls abutting one another - I have the dimensions for the brick coursing correct (join doesn't work).....why?
I guess I'm frustrated as to why this is so difficult - what are others doing that I'm not
Are these simple overlooked things, so what do I check or do if not?
If someone wants this file, I'll post it for you....
Thanks in advance…..
