Wall visibility through roof
Message 1 of 12
I have a project which is an existing building we are renovating.  I phased the building as needed.
To see walls through roof, I use the "Underlay" method.  However, when I attach the wall to the structure above, the wall disappears from my roof plan.  The weird thing is, it only happens to some of them.  If the wall is not attached, it does show up.  Now, this only happens when the Underlay Orientation is "Look Down".  When I "look up", my existing exterior walls don't show up at all but the new exterior walls do.  What am I doing wrong or what have I overlooked?  Or glitch?
Replies (11)
Message 2 of 12
I believe elements touched by the view range extent will not show as Underlay. That explains why the walls attached to the structure above don't show. Try to adjust the roof plan view range and make sure the primary range bottom is above the top of those walls.
Message 3 of 12
Are the walls Top Constraint Connected or Unconnected. Try Connected.
...see "Elements Intersected by the Cut Plane" section in Link:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Message 4 of 12
Thanks for the quick response.  This does work but I have different roof heights - sloped asphalt roof.  When I change the range and it goes above the lower roof, you can only see the top of roof for those areas.
Message 5 of 12
Tried connecting.  Didn't help.  Thanks for your suggestion.
Message 6 of 12
You can increase View depth to capture the lowest roof. View depth doesn't affect Underlay elements.
Message 7 of 12
I've changed the view depth to to -50' and I still cannot see the lower walls through the roof.  I can see roof, but not walls.  The highest point on my building is 24'-0" (peak of roof).
My settings are:
Top (bearing level = 12'): 32'
Cut Plane: (bearing level = 12'): 30'
Bottom: 23' (above 1st floor) (above the highest wall - 22'-10)
Depth: (level below 1st floor): -50' and switched to unlimited and no joy.
Message 8 of 12
You may try to use Plan regions on the lower roof areas and play with their view range.
Can you share the file?
Message 9 of 12
Message 10 of 12
What's your View Phase Filter setting? Try "None".
@Anonymous , can't you just attach the RVT?
Message 11 of 12
Either Autodesk utilizes a potato for their server or our office is using a dial-up connection because it estimates 1 hour to download the file.
Message 12 of 12
Use a Plan region.
