Room Boundary prevented from expanding by unknown barrier?
12 ANTWORTEN 12
Nachricht 1 von 13
1006 Aufrufe, 12 Antworten
I have one room in my model that will not expand to fill the entire space. It appears to be separated by an unknown model element, however, there is no perceptible room bounding element or separation line on that level or the level below that would limit the room.
Any ideas?
Tags (1)
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: Anonymous
Turn on hidden worksets, reveal hidden elements and cut a section see if you find anything.
Nachricht 3 von 13
Does it fill in when you lower the cut plane in the view?  Is there a sloped ceiling over that area?  Area and Volumes being calculated?
Nachricht 4 von 13
als Antwort auf: ToanDN
Still no luck after cutting section and showing hidden elements and worksets
Nachricht 5 von 13
What are the properties of the wall below?  Make sure its unconnected height shorter than the floor to floor height, then attach its top to the floor.
Nachricht 6 von 13
Thanks All,
1. I made the stud wall below unconnected and set it below the 2nd floor, then I attached it to the 2nd floor.
2. The building is existing (structure and floors), everything else is phased new construction, including the rooms.
3. There is a sloped "sawtooth" roof above the room area in issue (however this sloped roof does extend over a portion of the room that is being calculated.
4. No volume appears to be calculating.
room problem section - long.JPGroom problem section.JPGRoom Problem, capture.JPG
Nachricht 7 von 13
Okay, create a new plan view of the level highlighted below and see if any room separation lines appear on that level.
Nachricht 8 von 13
I was not able to find any room separation line. What I found was the wall below was impacting the room on the 2nd level.  I'm not sure what the fix is, If I "unbound" the wall below, it fixes the room above but destroys several rooms below.
Nachricht 9 von 13
Can you select that wall and show its properties?
Nachricht 10 von 13
Nachricht 11 von 13
Can you post the file? Might be faster and easier to troubleshoot seeing the file.
Nachricht 12 von 13
als Antwort auf: barthbradley
I tried, unfortunately the file is quite large and exceeds the upload limit
Nachricht 13 von 13
It looks normal so I have no idea.  Maybe keep it unbound and draw separation lines in level 1 to fix the rooms on that level.  Or you can share the file.
