wall tag leader gap
7 REPLIES 7
Message 1 of 8
4419 Views, 7 Replies
wall tag leader gap
Does anybody know how to close in the gap on the leader and the box on my wall tag? See snippetwall tag gap.PNG
Thanks in advance! 🙂
7 REPLIES 7
Message 2 of 8
ennujozlagam
@Anonymous hello, edit your family and adjust line below. see attached. thanks
Message 3 of 8
Try change the label type boundary distance to 0. If it does nit fix it then you have this make the box a bit bigger.
Message 4 of 8
in reply to: ennujozlagam
Hello @ennujozlagam, thanks for that. How do I edit the leader in the family. Does it have it's own section? I have looked in the family and there isn't a leader option anywhere. Am I looking in the wrong place?
Cheers! 🙂
Message 5 of 8
@ToanDN is it this one I have to make 0?
Message 6 of 8
Yes.  But there will be a gap from the label to the leader even if you make it 0.  As @ennujozlagam and I said, you may still need to enlarge the box a little.
Message 7 of 8
ennujozlagam
@Anonymous  hello, either your pick wall tag and go edit family or go to project browser and pick wall tag and edit,  save and reload again. thanks
there is no leader option it only appear once you load the wall tag family, you can also add arrow just go to edit type. please see screen shot. thanks
Message 8 of 8
in reply to: ToanDN
@ennujozlagam and @ToanDN You guys are the best!!! 😄
