wall split horizontally, still connected between them
xu.teng
Message 1 of 13
xu.teng
When i am trying to move one of the wall, the other one follows. how can i break this connectiong?
https://forums.autodesk.com/t5/revit-architecture-forum/wall-split-how-to-separate-resulting-element...
i found a old post about the same problem, but i cannot use tab to find the slit line. can someone help?
Replies (12)
Message 2 of 13
Reveal Constraints and unlock the constraint.
Message 3 of 13
Interesting @ToanDN.  That doesn't seem to work for me with a horizontally split wall.  Split with Gap and deleting the in-between wall allows me to gain independent control of top and bottom walls though.
My Revit must be broken.  Arrgh.
Message 4 of 13
@xu.teng...Selecting one of the Split Walls and Clipboard Cut/Paste Aligned to Same Place seems to be a workaround as well.
Message 5 of 13
Same question.
https://forums.autodesk.com/t5/revit-architecture-forum/unjoining-walls-after-creating-split-in-elev...
Message 6 of 13
Got it. My bad. Thanks, @ToanDN
Message 7 of 13
xu.teng
@ToanDN @barthbradley
thanks for your guys help. But there seems no constrains on my walls, and when i move them, you can see the upper wall follows. i am trying to slit one of my wall and delete the constrains, but when i move them horizontally, both of them moved. do i miss something?
Message 8 of 13
RDAOU
@xu.teng
Can u attach the model or a partial copy of it for a closer look at the issue?
I am guessing that those splits are in the wall type structure
Message 9 of 13
xu.teng
tried a couple times again, i can only break the vertical connections, but horizontally. they follow each other when moved
Message 10 of 13
REVEAL CONSTRAINTS.
Message 11 of 13
xu.teng
@RDAOU @barthbradley @ToanDN
Here is the model, i have delete the constraints, but not working for horizontal moving
Message 12 of 13
Message 13 of 13
xu.teng
thank you. it works now when i check disjoin.
