Image as material
Image as material
yes_and_no
Message 1 of 23
Image as material
yes_and_no
Guys, you can see there is a Cezanne painting on the wall. I used image for material, and no matter what x,y scale I tried, the painting won't fit to the...painting. Did I miss anything ?
Accepted solutions (3)
Replies (22)
Message 2 of 23
Use the Image in a Decal.
...is the geometry you are painting the same size as the Image?  If so, maybe there is a Position Offset?
Message 3 of 23
syman2000
Usually I would use model hatch pattern
Make the hatch size the same as artwork
Move the hatch pattern
Result
Message 4 of 23
RDAOU
@yes_and_no
That happens when the image is tiled...
Usually if the image has been scaled to the right size and it matches the frame dimensions...when the image Repeat is set to NONE, the image will fit.
Otherwise, if you keep it tiled, you will need to align to the edges using the method highlighted by @syman2000
Message 5 of 23
RDAOU
Message 6 of 23
yes_and_no
I don't understand the step "move the hatch pattern", so I set the tiled" to "none". Result: I got a blank painting instead.
Message 7 of 23
RDAOU
@yes_and_no
I must have GIF'ed the screen capture from photoshop lol...
Apparently after all the testing you have been made, the center of that image is way off the center of that Frame. Your only option now is what @syman2000  suggested
  1. Use Tiled for the image>>
  2. Under graphics tab >> apply a model crosshatch Surface Pattern
  3. Switch to view Hidden Lines >>
  4. Use the align tool to align the vertical and horizontal lines of the model surface pattern to the edges of the frame
  5. Switch back to realistic to validate image tiles shifted
Is that Frame a family or an in-place extrusion?...preferable if you use the former where you would be able to ensure the image aligns to the frame before insert to project.
Message 8 of 23
Are you using Revit or Revit LT?
Message 9 of 23
yes_and_no
I posted the image and R17 family here, perhaps you guys can help.
I scratched my head for too long on this.
Message 10 of 23
syman2000
No sure what you did with the material. So I have to recreate them to make it work.
Message 11 of 23
Like this?
Your image:
Message 12 of 23
yes_and_no
Still not working on my end.
I kept everything the same.
Message 13 of 23
syman2000
I would delete the family. Purge it out and then reload the family back in it. Sometimes if you have existing object with material, it will override whatever is new and you won't see the changes.
Message 14 of 23
Because materials in project take over materials in families.  Delete the material in your project, purge the material asset, and reload the family that the fellows fixed for your, so that the new - correct material can come in.
Message 15 of 23
yes_and_no
I expected that to happen. Did delete, re insert, and no luck.
Message 16 of 23
syman2000
Try open new project and insert it in. See if that works. If that works, then something in your current project may hinder it from working. So you may want to add parameter to the artwork. In the project itself, you may want to recreate the material and then add that image.
Message 17 of 23
RDAOU
@yes_and_no
It will get tiled again in the project no matter what you do...because in the project you have 1 material asset but 10 sizes of the Picture frames. That is the purpose of Tile (to repeat image when offset/not centered to the surface applied to or when its dimension does not match that of the surface it is being applied to)
To get it right,
  1. You need to create a different/new material and a material asset for each frame type LxW.
  2. In each asset, the image need to be scaled to the Dimensions of the frame type
Message 18 of 23
yes_and_no
It works finally. Thank you all.
 To Toan: this is Rv17, not LT.
Message 19 of 23
Glad you've got it
If it is full Revit then why not using Decal tool as @barthbradley suggested in the very beginning?  It would be a walk in the park.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-D...
Message 20 of 23
yes_and_no
I don't think decal works in floating family.
