wall split horizontally, still connected between them
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
xu.teng
1056 Aufrufe, 12 Antworten
When i am trying to move one of the wall, the other one follows. how can i break this connectiong?
https://forums.autodesk.com/t5/revit-architecture-forum/wall-split-how-to-separate-resulting-element...
i found a old post about the same problem, but i cannot use tab to find the slit line. can someone help?
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: xu.teng
Reveal Constraints and unlock the constraint.
Nachricht 3 von 13
als Antwort auf: ToanDN
Interesting @ToanDN.  That doesn't seem to work for me with a horizontally split wall.  Split with Gap and deleting the in-between wall allows me to gain independent control of top and bottom walls though.
My Revit must be broken.  Arrgh.
Nachricht 4 von 13
@xu.teng...Selecting one of the Split Walls and Clipboard Cut/Paste Aligned to Same Place seems to be a workaround as well.
Nachricht 5 von 13
als Antwort auf: barthbradley
Same question.
https://forums.autodesk.com/t5/revit-architecture-forum/unjoining-walls-after-creating-split-in-elev...
Nachricht 6 von 13
Got it. My bad. Thanks, @ToanDN
Nachricht 7 von 13
xu.teng
@ToanDN @barthbradley
thanks for your guys help. But there seems no constrains on my walls, and when i move them, you can see the upper wall follows. i am trying to slit one of my wall and delete the constrains, but when i move them horizontally, both of them moved. do i miss something?
Nachricht 8 von 13
RDAOU
@xu.teng
Can u attach the model or a partial copy of it for a closer look at the issue?
I am guessing that those splits are in the wall type structure
Nachricht 9 von 13
xu.teng
tried a couple times again, i can only break the vertical connections, but horizontally. they follow each other when moved
Nachricht 10 von 13
REVEAL CONSTRAINTS.
Nachricht 11 von 13
xu.teng
@RDAOU @barthbradley @ToanDN
Here is the model, i have delete the constraints, but not working for horizontal moving
Nachricht 12 von 13
Nachricht 13 von 13
xu.teng
thank you. it works now when i check disjoin.
