- Mute
- Permalink
- Report
In the last day, many of my elevation views are displaying with transparent walls even though I have a View Template applied to ensure the proper view settings. A few of the elevations still look fine with the view template applied, but many look as if the wire-frame setting were applied, and I checked several times that the view is displaying as Hidden Line and Not Wireframe.
I've been working in this model for several weeks now, and this is the first time this problem has occurred. I have my elevation sheets all set up, and they were printing perfectly just a day ago.
Please see the attached photos for reference. The first photo shows the view error, and the second photos show an elevation that is displaying properly.
This is everything I have checked to try to fix this problem:
- Wall visibility setting
- Element graphic overrides
- Hidden Line vs. Wireframe
- Phase settings
- Changing the wall types
- Even creating new elevations. All new elevations I create are defaulting to this error-ed transparent wall view.
Please share any suggestions you may have! Thank You!
