Wall shaded appearance
tmccar
Advisor Advisor
Message 1 of 11
tmccar
The sloping wall was modelled in place, and has the same material as the straight wall. Why is the appearance different?
Replies (10)
Message 2 of 11
cbcarch
Different Phase?
Check wall Phase, and/or Set View Phase Filter to Show Complete
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 11
Is the model in place category correct? Is that category being overridden in the view template or visibility graphics?
Message 4 of 11
tmccar
@cbcarchwrote:
Different Phase?
They're both "New Construction"
Message 5 of 11
tmccar
It was definitely modelled using the Wall category.
There's no view template
Message 6 of 11
cbcarch
Any "Paint" applied? Try "Remove Paint" or set to "By Category"
Triple check if Material is identical to other system wall families.
Cliff B. Collins
Message 7 of 11
Did you assign the material to the solid in the editing mode?
I don't see the entire wall but from what I see, it can be done with normal wall with edited profile.
Message 8 of 11
tmccar
No paint applied and material is "cast in place concrete" like other wall.
Message 9 of 11
tmccar
How can this be achieved with a normal wall?
Message 10 of 11
Edit profile.
Message 11 of 11
tmccar
@ToanDNwrote:
Edit profile.
Thank You
