Wall Schedule with Windows and Doors
Message 1 of 8
Hi!
I'm looking for a way to build a Wall Schedule which would also show the doors/windows present on each wall.
I tried using the Mark parameter, inputting for each wall the tag number of each door and window, but it's too much work for a big project. Is there a way to automatically show which doors or windows are on each wall?
Example: I want a schedule like this:
Wall Schedule
Type         |  Area  |  Height  |  Window  |  Door  |
Concrete  |  4 m²  |   2 m     |   W01       |  D01   |
Brick        |  6 m²  |   2 m     |    W02      |  D02   |
If anyone could help me please! Thanks 🙂
Replies (7)
Message 2 of 8
There is no direct way and automated to do it in Revit. But you can create a Dynamo script to copy the host (wall) information to the doors and windows and use it in a door/window schedule.
Message 3 of 8
Hmm then it won't work for what I need. I need the type and area of the wall and then the window/door on that wall. Bc the way I have to pay my wall contractor is by discounting only windows or door areas bigger than 2 sq.m. Less than that, I pay as if it was a whole wall, with no openings.
Thanks!
Message 4 of 8
Sahay_R
If you create a Wall schedule with an Area parameter field, it will calculate the area of the wall minus the area of doors and windows. This might help.....
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 5 of 8
Edit:  I made a mistake.  The contract wall area should be the Wall Area + the Area of Doors/Windows less than 2 sqm like in the image below.  the screencast show subtraction and it is wrong.  Revit 2017 file attached.
@Anonymous
Dynamo can help speed it up by reading the Wall ID and writing it to the Doors/Windows ID for scheduling, and potentially reading the Doors/Windows Area (with < 2 m2 filter) and writing it back to the Walls.
See screencast for a manual approach.  It's kinda long because I did it from scratch and on the fly with my thought process.
Message 6 of 8
Here is another approach. Put all the windows less than 2m2 in a later phase. Schedule your walls in the current phase and it should exclude those windows area.
Message 7 of 8
Thank you for the screencast and all your support!!
@ToanDN
If I was modeling from zero I believe that would be the best solution, even though it's still very "manual" (would have to input each window and door area into the wall schedule - even though I could export everything to Excel and do it quick).
But since I got a finished model from the architects the last option you suggested fits my needs in a better way.
Message 8 of 8
Sahay_R
You can add a formula driven Area parameter to the window families, and have them involved in the schedule and the calculation formula. Less manual involvement for you.
Rina Sahay
