Is there any way in Revit that the object inherits instance parameters (shared parameters) from another object? Let's say I have furniture in a room, and all of them need to have the same value of parameter "Owner". If the owner changes, I have to change the Parameter value for each object separately. But if one object could inherit the value from different one, I could only change the value for one of them and all the rest would be updated automatically.
I know I could use global Parameters for this cause in some way, but it would be difficult to manage the project.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
It sounds like a family or type parameter would have been a better choice than instance.
You could select all instances in view or project and change it in the properties box.
