Wall Reveal - Structure
hello everybody,
i am trying to apply a reveal profile to a wall which has a 18cm+1,5cm structure.
i want the exterior layer (1,5cm) to follow the reveal-profile (2cm). is it possible or i should try modeling in place?
Thanks!!
I would use Cut Profile or filled region to fix large scale detail drawings only and leave small scale sections alone.
Alan.johnson1970
I would add the reveal in the wall and then add a 'model in place' sweep in the same place with the the shape you need at thickness of the layer and the same material.
Although I guess if you created a profile you could just add the sweep in the wall with the reveal.
or you could just add the detail as lines in your section.
AJ.
Karol_Piroska
maybe you could try to add a sweep with same material at same location as the reveal?
loboarch
This would be the approach I would try to. Probably cause the least amount of problems in the long run, and would probably be the quickest solution too.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
I'm kind of thinking along the same lines as most of you, except I might do it as a line-based family with an unattached void in it to cut the project wall ("Cut with Void when Loaded"). My two-cents worth.
