Wall Profile issue.
2 REPLIES 2
280 Views, 2 Replies
Wall Profile issue.
When attempting to change the profile of a wall with the Modify|Walls tool I get an error messages, one saying that the lines cannot intersect.  This only happens when trying to change the boundry of the existing wall, lets say miter the top corners.  I can add any cut out shape to the wall using Modify|Walls long as the shape does not touch the existing parimeter.  I know this is a baic wall profile edit but for some reason  I am missing something.  Any thoughs are greatly apprecitated.
Screen grab of what I am talking about, can edit any shapes inside the parimeter but as soon as I attempt to edit the shape of the wall I get the error.
2 REPLIES 2
L.Maas
Your screenhsot is not very clear. However I think what i happening is what I have on the left side (gives error).
However to make it work (miter) it should be as on the right side of my screenshot, so remove/shorten the lines making the corner until the miter point
Profile.png.
Louis
Please mention Revit version, especially when uploading Revit files.
in reply to: L.Maas
Thank you Enllnt!! That is the solution to my problem. Thanks for taking the time to answer my noob question.
Forma Design Contest
