Hii
Im really new to revit.
How do make the core and plastering work properly in this joint.
In wall joint setting i get only 2 settings
Solved by RDAOU. Go to Solution.
@Anonymous
Wall layers join based on the following:
Example Below:
Type 1:
Type 2:
Those are not universal settings, sometimes one combination doesn't work and one would need to try another
@Anonymous
If it Wraps around the column meaning the column is entirely embedded in wall...
Option 1:
Reduce the size of the column a value = plaster thickness? this way when you join geometry the wall plaster will wrap the column
Option 2:
you can edit the column family and add a plaster layer (another extrusion)
Option 3: (Only if you are familiar with Parts)
Converting the wall to parts allow you to control layers separately by enabling shape handles / grips
