I have this wall, where there are patterns only on the finish of both sides, no patterns in between. The moment you pull down any outside layer by modifying the vertical structure. The second layer from the outside will show the pattern on the opposite finish.
Unlocking the finish
Pull down the small grid finish, big grid finish shows instead of the gyp
Pull the other side down, same thing happened.
Tried this on Revit 23, 22, 20. Same result
Tried turn off Wrap, same result.
Solved by Peter_Yau. Go to Solution.
Solved by ToanDN. Go to Solution.
Hi @Peter_Yau
Thanks a lot for posting your question to the forums! Has the solution suggested by @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
hey Jonathan, thanks for checking in. Parts is a great suggestion but its a work around, there are potential risks of using parts, we try to avoid parts when possible. Another workaround would be painting the surface with the correct material, both of these works but they both require extra steps labor. it will be great if Autodesk can fix this in the back end.
Hi @Peter_Yau
Thanks for coming back to me. It sounds like a great suggestion for the Revit Ideas platform.
It would be great for you to take a look there and maybe submit an idea for a modification to the wall tool.
Jonathan Hand
