wall opening not cutting through stacked wall
6 REPLIES 6
mikeferne
293 Views, 6 Replies
I have a simple stacked wall and I need to make an opening through it. I have tried used int opening "wall" tool but it seems to offset the opening by 10mm and doesn't cut all the way. I have no way to move the opening over at all. Everything is on the existing phase. So far my work around is to use a structural door opening.
If I use the opening tool on a non-stacked wall, no problem. Door and windows also cut the stacked wall no problem.
See attached.
Any ideas??
6 REPLIES 6
Maybe edit wall profile helps
mikeferne
in reply to: mikeferne
Yea could do that or model in place a void, but that still doesn't fix this issue.
Pick Primary Host?
mikeferne
in reply to: barthbradley
What tab are you in there, its just off the screen shot. I don't have that option.
Post your Project File and we'll take a look and see.
Use the Opening Family from Revit door library.
Forma Design Contest
