Wall Location Line Shortkey ?
Hi everyone !
One of my drawers use to have a short key on a previous software to swap the location line while drawing walls.
Is there a shortkey on Revit 2018 which allow you to swap the location line without  go on the green rubon click on "Location Line" ?
There is no such option in the short key parameters of Revit and nothing is mentionned in Autodesk Help... I checked another forum who says it isn't but since the post was already 8 years old I thought maybe it is now.
Thanks !
Ilic.Andrej
I'm under the impression he used a plugin shortcut.
Here s a topic about a similar tool.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Only thing that comes to my mind is hitting space key to only switch sides while drawing (but not directly changing location line though)- maybe that was it?
hum... not exactly, I think there isn't such shortcut now 😕
maybe in the next version ^^
Alfredo_Medina
Lots of things will be different. Some things from the old software have an equivalent tool. However, most of them don't. And there are a lot of new tools to learn.
Rambazamba73
Why do you mark a topic as solved when it isn`t ? There is no solution yet.
You are ruining the hole forum with this !
