wall joint
wall joint
yazan.hijazeen
Message 1 of 20
wall joint
yazan.hijazeen
Hi everyone,
we have at our model this situation where 2 walls are connected, but because both have different hight dependencies , the connection is not clean, i tried to adjust it with the wall connection tool, but it does not work. Does anyone know how can I solve it? Thanks in advance.
Replies (19)
Message 2 of 20
What are you trying solve exactly?
....where is the plan view cut plane located? Above that 3D geometry or through it?  If above  it, then the plan view looks correct to me.
Message 3 of 20
I think it's all about the Plan View's View Range Cut Plane.  Does raising it or lowering it solve?
Message 4 of 20
yazan.hijazeen
what i am trying to solve here, is to remove the line between the joint walls as shown in the screenshot to have a clean joint, I also tried playing with the viewRange cut plane, but it's not changing anything.
Message 5 of 20
If you are actually cutting through all those walls - and they are joined - then that linework shouldn't be there.
Maybe Phasing? Set Phase Filter to Show Complete.
Message 6 of 20
Message 7 of 20
What is the condition at the base of these walls?
Message 8 of 20
yazan.hijazeen
so all 3 walls share the same base level with no extension
Message 9 of 20
yazan.hijazeen
so I did a quick test, where i drew walls as a chain and then modified the top constrain as required, the joint is still clean, but this means, the walls need to be replaced as a chain and this is not practical, as I have multiple similar situation.
Message 10 of 20
Can you isolate the 3 walls and show a 3d view looking at the base?
Message 11 of 20
yazan.hijazeen
Message 12 of 20
The bases appear to be at different heights (maybe attached to something), are they not?
Message 13 of 20
yazan.hijazeen
yes, they share the same base constrain, but attached to different Floors
Message 14 of 20
Is your view Hidden or Wireframe?  Are walls category, or wall elements transparent?
Message 15 of 20
yazan.hijazeen
the view is set to Hidden and walls are not transparent.
Message 16 of 20
I am asking about the plan view, not the 3d view.
Message 17 of 20
yazan.hijazeen
sorry, same settings in plan view
Message 18 of 20
Can you share the file?
Message 19 of 20
yazan.hijazeen
unfortunaltely, i can't share work related information.😕
Message 20 of 20
Do you see the lines if you create a new plan view from scratch, not duplicating from another view?
