Wall hosted profile
Wall hosted profile
Message 1 of 11
Wall hosted profile
Good morning.
I created a family for a wainscot using a profile and I need it to be hosted by default to a wall
any suggestions please?
Thank you
Replies (10)
Message 2 of 11
No, the profile cannot be hosted, but the geometry you are creating from it can be.
So, how are you creating the wainscot geometry? Sweep?
Message 3 of 11
yes, how can I please host the geometry?
thank you
Message 4 of 11
Create the profile and assign it to a Wall Sweep type.
Message 5 of 11
What is the Profile Usage?
Message 6 of 11
Another technique often used to do wainscoting, is through a Stack Wall.  If it's an Exterior Wall, you may want to do it that way instead of as a Sweep.  Check out Revit's stock Stacked Wall to see what I mean.
Message 7 of 11
WarrenRoberts
What you are saying makes sense to me. However, the reason I found this thread is because I wish to know what the family template file, "Profile-Hosted," is about and how to use it.
Message 9 of 11
WarrenRoberts
I have no idea what you are trying to express to me. That link is about Revit fundamentals -- how to create a profile family. I have over 15k hours of Revit time so I kind of know how to do that. The link doesn't make any reference to a hosted profile. Check the attachment to my posting.
Message 10 of 11
Your question was: "what the family template file, 'Profile-Hosted" , is about and how to use it" That link I posted answers this question in depth. Read it and its hyperlinks.
Maybe this picture will help too:
Message 11 of 11
WarrenRoberts
A couple of hours after my reply, I did just that--I opened the template.
Then I was able to see how it is used. I think Autodesk words it in such a way as to imply that the profile itself is responsible for the hosting/attachment which is not the case. As you stated and as I see now, that it is a template that is typically used with hosted families but the hosting comes from the characteristics of the family and not the profile. In other words, I could create a sweep in a generic model using a profile created in that template but it still would not behave like a hosted element because the basic generic model family is not a hosted family.
Thank you.
