Wall framing layout
Wall framing layout
wisedrawing
Wall framing layout
wisedrawing
So at the beginning of my career the rule was floor plans to have studs only (with light weight cladding and internal walls - don't show these) as you are drawings for the carpenters to set out. Pen work and 2D CAD days. Brick you added the cavity and brick but they could work with that. Now we all have endless cladding materials all with different thickness and obviously using multiple materials and different sized studs etc.
All in all it means now with Revit I am adding the wall claddings, material notes and internal plasterboard etc. which is great for most of the detailing
But I want to create a framing only plan - so in plan view can I drop off the cladding in visibility and pick up the component that I want left (stud) and therefore dimension that off.
at present I am starting to pick off the stud with 'tab' command which is taking a bit of time
I have looked through VG but cant see that option
thoughts
Accepted solutions (3)
ralphdenhaan
You can change your wall type and move the finish materials outside the core and then use the VG settings (see printscreen). Another way is to model each wall separately and use filters, for example.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
wr.marshall
For the actual frame elements make them something like structural framing or Generic models... (whatever works for you and then hide the walls so only framing is visible.
For interest see this revit idea: Walls have framing..... - Autodesk Community
Turn off non-core layers, or create parts from walls and turn off parts based on materials.
wisedrawing
Toan
how does the 'parts' work?
capr_i_rus_07_4
Community Visitor
Community Visitor
To create a framing-only plan in Revit, use View Filters and Subcategories within your wall assemblies. Assign a unique material or subcategory to the stud layer, then apply filters to isolate it in plan view. This method hides cladding and finish layers while keeping the framing visible for accurate dimensioning. It’s a clean solution that avoids constantly modifying wall types or duplicating assemblies.
Another effective approach is building a Framing Plan View Template. Once configured, it allows you to reuse the setup across multiple projects, saving significant time when dealing with various wall types, material thicknesses, and cladding combinations. This setup ensures consistent visibility control and makes it easier to coordinate between architectural and structural views.
Such precision in framing layouts is essential during remodeling and renovation work, especially in environments where different wall finishes or materials meet. Teams handling Handyman Services Singapore often apply similar Revit workflows to prepare accurate framing and wall reinforcement plans before on-site construction.
For those who want to see how framing visualization connects with practical renovation techniques, you can click here to explore how detailed layouts improve efficiency and construction accuracy.
