Wall Foundation Not Room Bounding
8 REPLIES 8
Message 1 of 9
PhilvK
400 Views, 8 Replies
PhilvK
I added curbs to walls by using a 6" Wall Foundation attached to the base of the walls by just selecting the walls. The base of the walls are offset 6". The wall foundations are not room bounding so I can't place a room unless I add a room separator along the walls. Is there a way to make the wall foundation room bounding?
8 REPLIES 8
Message 2 of 9
hmunsell
in reply to: PhilvK
hmunsell
i don't believe Wall Foundations can be room bounding. Change the Computation height of the room to be above the Foundation you placed.
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-2945C619-2AE6-455D-823C-E4F6AE759B8E
Or you can just use a Stacked Wall and set the base as a 6" Concrete.
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-CC9640A1-199E-49E3-A036-01B960CD2B78
Howard Munsell
Howard Munsell
Message 3 of 9
MichaelDol
in reply to: PhilvK
MichaelDol
Mikhail Dolgikh / Михаил Долгих
BIM-Manager & Teacher / БИМ-Менеджер - Учитель
Facebook
Facebook
Message 4 of 9
PhilvK
in reply to: hmunsell
PhilvK
Thank you. I thought of stacked walls, but hadn't thought of the computational height.
Message 5 of 9
PhilvK
PhilvK
I tried stacked walls with a curb for the lower wall, and a wall with layers for the upper one. I want the outer layer of the upper wall to be able to be extended past the face of the curb to the floor but I can't get the layers unlocked for the upper wall. Does stacking of walls prevent unlocking layers?
Message 6 of 9
in reply to: PhilvK
Break the stacked walls to individual walls.
By the way, it sounds overly complicated.  Why can't you use a Foundation Wall type or a Foundation Slab for the Foundation?
Message 7 of 9
PhilvK
in reply to: ToanDN
PhilvK
I usually use the individual walls. Just experimenting with the stacked approach.
Message 8 of 9
in reply to: PhilvK
You can select a stacked wall and Break it.
Message 9 of 9
PhilvK
in reply to: ToanDN
PhilvK
Prefect! Thank  you.
Prefect! Thank  you.
