WALL FINISH OUTER BOUNDARY HELP URGENT :(
I have been doing my Project smoothly without any errors up until recently when i faced an issue in my materials library and had to re-install my Revit.
After Re-Installing I opened my Project and noticed some uneven balance on the LINES that define the wall BOUNDARY. They cover up my wall FINISHES and i can't able to solve neither did i come across a similar problem on this forum and i had to post. Here are some screenshots just to give you an idea on what is exactly the problem.
I posted the screenshot of a glass wall too just to give you an idea on how the boundary lines are pixelated. The glass wall is 1 inch but the outer boundary lines are out of proportions. This is throughout my plan and even on a new project file. I have tried using my colleagues file but they turn out this way once load into my laptop.
I use windows 10. DELL core i7, AMD radeon.
Moreover, I have tried literally almost everything from visibility graphics to controlling LINEWEIGHTS. The project looks fine with THIN LINE mode but once printed it comes out in this original alien format. I tried editing the wall ASSEMBLY but nothing has worked.
I have almost reached my deadline and i need some urgent help at this stage.
Thanks.
regards,
I don't see anything wrong.
I don't see anything wrong either. Guess we pin-pointed the problem. It's your monitor.
