Revit doesn't work correctly with the second monitor
Message 1 of 9
Hello everyone,
I have no clue why Revit doesn't show correctly the informations when I click on the Location line box ( attached image ), as well as when I modify the levels in the Properties, the informations didn'T show up. I use the second monitor (Dell U2417H) with my laptop.
I think the problem could be that due to the different sizes between my laptop screen (15")  and the external monitor (24").
Does anybody know how can I fix it?
Thanks a lot
TT
Replies (8)
Message 2 of 9
I connect my 17" laptop to a 34" monitor. No problem. Not understanding what shown incorrectly in your screenshot by the way?
Message 3 of 9
Thank you for your response.
what I thought is that the appeared box ( when I click for instance modifying the Locaiton Line of the Wall) doesn't show up in the right position where it should be located.
I made again 2 screenshots for showing you what I actually meant. once on my laptop screen (15", correct position) and once on the monitor (24", incorrect position).
Thank you and looking forward to your help.
Message 4 of 9
-FDC-
Can you make a screenshot from the whole screen ?
Message 5 of 9
Okay so the drop-down list does not line up with the drop-down box?
What are the resolutions of the 15" screen and the 24" screen?  What is the display scaling?
Message 6 of 9
Yes exactly. The resolutions of both screens are similar ( 1920 x 1080 ). but the scaling is different. 100% with the 24" screen and 125% with the 15" screen ( 100% is too difficult to read on the 15" screen ). do you think the various scaling of 2 screens could cause this problem?
Message 7 of 9
Yes sure
Message 8 of 9
Give them the same display scaling.
Message 9 of 9
Thank you. it works perfectly 🙂
