RPC families not showing up in realistic view style
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
2620 Aufrufe, 2 Antworten
I've got a problem with the default RPC revit families.
They don't show up as the rpc image in the realistic view style (only the normal 3d geometry), thought they render fine.
That problem happens in all my projects that are created with my working template (created with an old version of revit and updated ever since).
If I open the family, or a revit standard template it works fine.
So there is a problem with my template that prevents rpc images to display in realistic view style. The question is where the bug is and how can I solve it.
I'm working now with revit 2018, but this problem exist since 2017 (everything was fine before that).
If anyone can help with this problem I would really apreciate, since a lot of projects are already created with the faulty template, so remaking the template is not an option for those.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
I forgot that you can't replicated the problem so I will attach the faulty template totally purged with only an rpc tree family. (had to change the .rte file to .rvt, because it refused the upload).
Let me add that I tried to remove all instances of the trees and purge, as to remove the "memory" of the old families, and add the rpc family from 2018 revit library, but the problem percisted, as you can see.
Please help!
Nachricht 3 von 3
Reset the category override below:
