wall custome
5 REPLIES 5
208 Views, 5 Replies
wall custome
Hi i want to custome wall suit to facade can you help me ? Thank you
I attach the file too
5 REPLIES 5
Use the Wall Edit Profile tool.
Edit the wall profile in 3D or draw an elevation looking at the wall if you want to do it in 2D.
in reply to: barthbradley
I have tried, but it doesnt suit 100% with the facade surface.
in reply to: ToanDN
Thank you. I will try
Yeah, I tried. You've got a challenge. There is no smooth surface in contact with your walls. You need to figure out how
the wall will meet the facade in the real world.  That's a design challenge; not a limitation of Revit. Revit can't make that decision for you. But, you can shape the walls any way you want using wall Edit Profile tool.
Forma Design Contest
