Wall corners acting weird
HNAP_Julian_JBO
Message 1 of 15
HNAP_Julian_JBO
i have joined two walls, the bottom one is overlapping the wall above,
Top wall goes strangely down (to its base offset = 0 )in the corners.
How to avoid it?
Wall joins doesn't help.
Attached Revit 2024 file.
Replies (14)
Message 2 of 15
vitorbortoncello
drag up using shape handle
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 3 of 15
HNAP_Julian_JBO
Dragging up (i.e.) changing walls Base offset is not an option, because I need the wall part on the 'internal' side to stay low, while 'external' side stay higher.
Modifying layers for vertical up/down flexibility is not giving good results either.
Message 4 of 15
vitorbortoncello
Well, for a definitive solution, I believe modeling two walls with two heights and then joining them is the easiest way
Message 5 of 15
Switch Join Order
Help | Join Geometry | Autodesk
Message 6 of 15
HNAP_Julian_JBO
That is exactly how I did it.
Message 7 of 15
HNAP_Julian_JBO
Switch Join Order makes the top wall come lower. I need the opposite:
Message 8 of 15
Look back at my screenshots. I used Switch Join Order to achieve BOTH conditions.
Message 9 of 15
HNAP_Julian_JBO
@barthbradley  it is a mystery to me how you made it work with Switch Join Order. I tried it in the video below, no luck.
(view in My Videos)
Message 10 of 15
HNAP_Julian_JBO
Any idea how come it doesn't work for me? As you can see in the screencast above.
Message 11 of 15
ridantuo
Wall Joins should fix that 🤔 -- if this is the way.
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
Message 12 of 15
azad.Nanva
Why you use the join and Overlap in height?
I can not understand?
am i missing something?
(view in My Videos)
(view in My Videos)
Message 13 of 15
HNAP_Julian_JBO
Because bottom wall is only on the exterior side, see:
Message 14 of 15
HNAP_Julian_JBO
Wall joins - very time consuming and doesn't apply throughout the Model groups of walls.
Message 15 of 15
azad.Nanva
whach the new video.
this one:
(view in My Videos)
