Wall corners acting weird
14 REPLIES 14
Message 1 of 15
HNAP_Julian_JBO
595 Views, 14 Replies
i have joined two walls, the bottom one is overlapping the wall above,
Top wall goes strangely down (to its base offset = 0 )in the corners.
How to avoid it?
Wall joins doesn't help.
Attached Revit 2024 file.
14 REPLIES 14
Message 2 of 15
drag up using shape handle
Message 3 of 15
Dragging up (i.e.) changing walls Base offset is not an option, because I need the wall part on the 'internal' side to stay low, while 'external' side stay higher.
Modifying layers for vertical up/down flexibility is not giving good results either.
Message 4 of 15
Well, for a definitive solution, I believe modeling two walls with two heights and then joining them is the easiest way
Message 5 of 15
Switch Join Order
Help | Join Geometry | Autodesk
Message 6 of 15
That is exactly how I did it.
Message 7 of 15
Switch Join Order makes the top wall come lower. I need the opposite:
Message 8 of 15
Look back at my screenshots. I used Switch Join Order to achieve BOTH conditions.
Message 9 of 15
@barthbradley  it is a mystery to me how you made it work with Switch Join Order. I tried it in the video below, no luck.
Message 10 of 15
Any idea how come it doesn't work for me? As you can see in the screencast above.
Message 11 of 15
ridantuo
in reply to: HNAP_Julian_JBO
Wall Joins should fix that 🤔 -- if this is the way.
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
Message 12 of 15
Why you use the join and Overlap in height?
I can not understand?
am i missing something?
Message 13 of 15
Because bottom wall is only on the exterior side, see:
Message 14 of 15
HNAP_Julian_JBO
in reply to: ridantuo
Wall joins - very time consuming and doesn't apply throughout the Model groups of walls.
Message 15 of 15
whach the new video.
this one:
