Hi, i'm trying to make parts from a family that has 2 models inside, 1 is a coarse version with rectangle cornes and the other one is a fine version with round corners, when a make parts it only uses the fine version of the model, ¿there's anyway of using the coarse version instead?
It uses the highest in family. If no Fine or Medium, it will use Coarse.
Hi @Nicolas.pojmaevich
Thanks a lot for posting your question to the forums! Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
