Wall Assembly Elev. View
5 REPLIES 5
pnovak2
356 Views, 5 Replies
I ran into a Revit “problem” that I can’t resolve to my liking. Maybe there is no solution to it.
I have lots of raked partition walls in this project we need to have elevation views for. So, I created an assembly from the wall (the fastest way I guess) and created an elevation view. We use standard construction practices, so the two ends of the wall go from framing to framing. We frame first and drywall later. When the elevation view is created from the assembly the wall length is (1" too short), as the distance measured between the two finished (drywall) walls. Please see attached images.
Labels (3)
5 REPLIES 5
in reply to: pnovak2
Disallow Auto-Join and Join Manually via Join Geometry
pnovak2
in reply to: barthbradley
Yes, that is a workaround. Takes a lot of time when you have lots of walls, and gives you an ugly detail as well with the overlapping lines.
Peter
What about Parts=>Assembly?
Create Parts and exclude finish layers from Parts.  Then create Assembly from Parts.
pnovak2
Actually, that is not a bad idea. One extra step but I can live with that.
Thank you for that.
Peter
Forma Design Contest
Technology Administrators
