Wall & column cleanup issue using Phase filters
Message 1 of 13
Hello all;
We have an issue where we are creating existing plan, demo phasing, and new construction.  There is a pilaster in a masonry wall.  In existing phase the column cleans up with the wall, but in new construction it does not.  We have checked all the common issues - materials, top/bottom heights, view template filters, class (structural or architectural), cut profile, to name a few.  The only way that they are cleaning it up is in new construction phase they are using a "white color" detail line and drawing over it.
Thanks in advance...
Jleibold
Replies (12)
Message 2 of 13
Existing column/wall, or existing column/new wall, or new column/wall?
Message 3 of 13
Message 4 of 13
Can you share screenshots for both phases?  Is there any new wall in the closed proximity that messing up with the joint?
Message 5 of 13
No walls that are close...
1st image is it looking correctly, 2nd. one does not...
Message 6 of 13
Any chance the View Template for the New Plan set to Wireframe?
Message 7 of 13
Show All? What about Show Complete?
Message 8 of 13
Checked that and it wasn't the case....
Message 9 of 13
Sahay_R
Intriguing. Can you share a file, please?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 10 of 13
barthbradley,
Thanks for the reply...
Show All displays the "existing" as half-tone (gray) - which is what we want, but Show Complete is "by category" and will not show up half-tone (gray).
Message 11 of 13
Hello rsahayUZMK9,
How do you want me to send / share it with you?
Message 12 of 13
Sahay_R
The best approach would be to save a copy of your file (detached, if it is workshared), strip it down to the elements shown in your screenshot, and attach it to your next post.
Rina Sahay
Message 13 of 13
Viveka_CD
Hi @Anonymous
It's been a while and I'm checking back to see if you still needed assistance from the community. Please add a screenshot of your issue, and it will help us troubleshoot your issue further.
Looking forward to your reply update.
