Message 1 of 8
07:03 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
Using Revit LT 2018.
I have built a classical column (that I need for a project) as a family. It is a combination of extrusions, blends and sweeps all of which are fine.
To form the fluting on the column shaft I have used void extrusions.
These also seem fine until I place them in a project and change the level of the column.
The column will move to the level as expected but the fluting (the voids cutting into the shaft) seem to stay at a default level (see attached screen grab).
I've tried playing around with the family but with no luck.
Any suggestions....?
EM
