Issues When Rendering Large Images
duguid
duguid
I've been having an issue when rendering a larger site rendering view within Revit (not using the cloud).
When I render the entire image, it produces blurry lines and jagged edges.
When I render in regions (at same resolution settings) the image comes out correctly, with crisp lines and defined edges.
This is forcing me to render the image in 4-6 sections and stitch them together in Photoshop.
Is anyone else having/had the same issue and know what I can do to correct it?
Computer setup is 6-core 3.7gHz, 32GB RAM, 8GB GTX1070 GPU, so the computer specs should not be the issue.
Full RenderFull RenderRegion RenderRegion Render
Viveka_CD
Hi @duguid
What is your file size?
Make a copy of the model, set up the camera view and delete the elements behind, i.e, not visible in the view and rendering again.
Is the issue specific to a user/ camera view?
Are your Smooth Lines with Anti-Aliasing enabled?
Can you try to skip/hide the entourage and environment, try rendering again?
Let me know if this helps or you can consider sending me a file to test, and I can share a private upload folder.
Viveka_CD
Hi @duguid
I just wanted to follow up here, any progress on this issue?
Can you share a file to test if the issue persists? Looking forward to hearing from you.
Viveka_CD
Hi @duguid
Just checking in once again to see if you've made progress on this issue?
Let us know if you seek more assistance.
Viveka_CD
Hi @duguid
I'm not sure if you are still out there! If you are:
I wanted to let you know that Revit 2019.0.1 has a patch for rendering issues:
  • Fixed an issue where the image size was very large for uncropped perspective renderings.
  • Added the ability to render a smaller region of the view in an uncropped perspective view.
Hoping to hear back from you!
