- Mute
- Permalink
- Report
I've been having an issue when rendering a larger site rendering view within Revit (not using the cloud).
When I render the entire image, it produces blurry lines and jagged edges.
When I render in regions (at same resolution settings) the image comes out correctly, with crisp lines and defined edges.
This is forcing me to render the image in 4-6 sections and stitch them together in Photoshop.
Is anyone else having/had the same issue and know what I can do to correct it?
Computer setup is 6-core 3.7gHz, 32GB RAM, 8GB GTX1070 GPU, so the computer specs should not be the issue.
Full Render
Region Render
