We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Voids not moving with family when placed in project
Message 1 of 8
Hi
Using Revit LT 2018.
I have built a classical column (that I need for a project) as a family. It is a combination of extrusions, blends and sweeps all of which are fine.
To form the fluting on the column shaft I have used void extrusions.
These also seem fine until I place them in a project and change the level of the column.
The column will move to the level as expected but the fluting (the voids cutting into the shaft) seem to stay at a default level (see attached screen grab).
I've tried playing around with the family but with no luck.
Any suggestions....?
EM
Replies (7)
Message 2 of 8
Hello @Anonymous,
Can you upload the family so we can check it.
cheers
Message 3 of 8
Corsten.Au
Hi
( work in Front Elevation of the family )
Create a Reference Line / plane at the top of the void ( flutes )
now lock the extrusion to that reference lines..
you may need to establish the distance between Levels - Reference line (for void ) - Level above..
dimension between level-ref line-level above and give parameters..
hope that helps..
Corsten
Building Designer
Message 4 of 8
Hi arjay.eco
Thanks for your response - I've attached the family.
EM
Message 5 of 8
Thank you ganesh,
I'll give that a try.
EM
Message 6 of 8
Hello @Anonymous,
I have to create several Reference Line to locked the Sweeps and extrusions. (shown in left elevation)
I also altered the Blend you've created and make it as Swept Blend and add an additional Parameters so you will be able to adjust height in the project.
I also create the void as Sweep so I can easily locked the path according to swept blend. (as shown in left elevation on how this being done)
I also create the top capital as Model Group (reference line and dimension included in a group) (as shown in the left elevation) and locked the group based on the top of Swept Blend so it will be able to adapt the height everytime there's a changes.
Please see attached family below.
Cheers,
Message 7 of 8
arjay.eco
Many thanks for that - really helpful.
I could not get parametrics, reference planes etc to work when I tried. I had settled on using the top plane of the objects the I was cutting as the refernce for the voids which stopped them moving about when I changed level within a project.
EM
Message 8 of 8
Hello,  I am a beginner and I cant seem to move the whole geometry. The void that I created stays behind. How do I solve this?
