- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
From my experimentation it doesn't appear possible to create a window (or door) family that can cut a floor via a void (nested or otherwise) that is nearby. I think the capability of this is hard-coded to only cut the host category type (such as wall).
I'm trying to create a fairly comprehensive exterior window and door family suite for my firm that has a variable parameter for sub sill depth and can therefore cut (with void) the slab or screed that the window would be sitting on, rather than requiring the drafting team to manually step the exterior outline of the slab in and out at each and every window, denoting the sub sill set downs.
It is working perfectly fine for the walls, but a floor just isn't being cut with the void (or opening) as I'm hoping to do.
Anyone have a neat workaround or proper way to undertake this?
Yes cut with voids is enabled, yes it is shared.
From my research it appears only the structural connection family category can work in this fashion??
