We work in a rail environment and model a lot of underbridges and overbridges. I'm wondering if anyone has any clever ideas on how they would model the surrounding embankments for a bridge?
We can't cut topography with elements (apart from building pads), and modelling as a generic model that is cut by the abutments can be a laborious task.
I would go with an in-place family.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
why not model it as a Floor? You can use Modify Sub Elements tools to shape edit the surface by adding points of varying elevations much the same way you shape edit a Toposurface by adding points. Set the Floor Material/Layer to "Variable" Thickness.
We use floors sometimes for basic abutment shapes, but for complex shapes it's not viable. Also I don't believe they can be cut by a loaded family unless it contains voids for cutting.
The laborious way ![]()
It is one of the more effective methods though.
It would be nice if topography got an overhaul and could be cut for tunnels etc. Instead of modelling with floors.
