Void cut out not showing up in in plan.
2 REPLIES 2
2307 Views, 2 Replies
Here is a sink model with a void cut out.
The problem is the cut out isn't showing up in the plan.
2 REPLIES 2
It the geometry even visible in Plan/RCP?  Check you Visibility Settings in the Family. I bet you only have a Masking Region visible.
...if you don't want Geometry visible in Plan/RCP, you can align and lock Symbolic Lines to the edges of the Void.  FWIW.
Yeah what @barthbradley said, You'll have a masking region inside your worktop family you'll need to edit to get the void to show.
A few screen grabs below the project on the left and the family on the right.
Family in plan within project not showing void family editor in 3D showing voidFamily in plan within project not showing void family editor in 3D showing voidedit masking regionedit masking regionlock the mask sketch to the void openinglock the mask sketch to the void openingload back into project void now showing because the mask has been editedload back into project void now showing because the mask has been edited
Forma Design Contest
