Visibilty in Site View
svilen2110
Message 1 of 19
svilen2110
The 3d Model in Site view is invisible. In all other Floor plans it is ok. Range in Properties browser is set to <unlimited> top& bottom. Also, ell elements of the Model are set to be visible. What might be the reason for that invisibility as Site view should show all existing level plans ?
Replies (18)
Message 2 of 19
Check Phase and Phase Filter. Check view crop region.
Message 3 of 19
svilen2110
Phase filter set to <none> or <show all> , or <show complete> - same situation. <Crop region visible> is on and it contains the Model area, still no change
Message 4 of 19
FGPerraudin
Have you checked it hasn't been hidden in view by mistake?
(click on the little "lamp" icon at the bottom of your view to make it visible. If apprearing in pink, you can select it and unse the options in the ribbon to make it visible)
Any template for your view?
François
Francois-Gabriel Perraudin
BIM management and coaching
Message 5 of 19
Is Model Display on View Properties Normal, Halftone, or None? Also, you clarified Phase Filter. What about Phase?
Message 6 of 19
svilen2110
Model display option is and Phase is , but makes no
difference if it is
Message 7 of 19
1-The 3D model could be hidden, click the reveal hidden elements button.
2-If your model is a linked rvt file than check your visibility settings for linked files
Message 8 of 19
svilen2110
There is not any hidden element in the view. Also no any view template.
This happens first time, really strange.
Message 9 of 19
svilen2110
Message 10 of 19
svilen2110
All elements are revealed, but still the Model is invisible. There is a
linked dwg. file and this one is visible in same Site plan.
Should I attach the file?
Message 11 of 19
if your model is the attached dwg file it might cause the problem, I suggest you check your visibility settings for the main file and for the linked file.
Message 12 of 19
svilen2110
The main rvt. 3d model is not linked, it is created in the same file. And
the 3d dwg. file that is linked, has no any problem with visibility. I have
checked few times the visibility setup, has to be visible the main model
and this problem occurs only in Site plan view.
Message 13 of 19
Feel free to attach your Revit file here if you want it to be looked at.
Message 14 of 19
svilen2110
ArtMuseumSeoul A01-1.dwg
​Hi, here is the dwg. file linked to the rvt. file and the rvt.file as
well. The visibility problem is only with the Revit model in Site view.
Thanks​
ArtMuseumSeoul A01-1.rvt
Message 15 of 19
svilen2110
Thanks​
Message 16 of 19
Nothing attached.
Message 17 of 19
I am curious did you solve the problem. If not it could be about view range settings or depth clipping in the properties window of the view.
Message 18 of 19
svilen2110
Thanks for the email. It is not yet solved. About view range-it is set to
unlimited top&bottom and there is no active clipping plane.
Already sent email to Autodesk Community with rvt. file attached.
Thanks for helping!
Message 19 of 19
@svilen2110
Whatever you are thinking you have attached are not there. Don't use email interface if you want to attach files. Use forum web interface.
