i cannot change some sections 'section names
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
1858 Aufrufe, 2 Antworten
 Kindly help me to fix this issue.
I made few sections and arranging in sheets, 2 of them I couldn't change its section names in "properties bar" but the changed names I can see in "project browser bar" .
For Exam- The default section name is "Section 67" I try to change this to  "Section-K4".But there is an error message appearing on screen.
kindly find the attachment screen shoot.
Txs
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: Anonymous
@Anonymous
  1. Did you change your user name in Revit options since you created those view? OR Does anyone else other than you work/use Revit from that PC?
  2. Did you try to open worksets and check views and/or tried to make that one editable ?
Is the model detached or still still linked to central?
Nachricht 3 von 3
als Antwort auf: RDAOU
NO, NO..
I didn't make any changes in Revit user options.
But , anyhow now it ok when I restart the Revit.....
Any way txs ur efforts.
