Visibility in Revit does not work
tranhang13798
tranhang13798
Hi everyone,
Recently I had a problem with visibility in Revit. Everything all shows up in 3d views but when it comes to a floor plan, it shows blank at all. I have checked such related things to visibility(Phase, Phase filter, VV command, view range....) but it did not work. Can you guys have any solution for this?
Thank you so much.
anze.kumar
Discipline ("Coordination" or "Structural"..)?
Filters?
do you have any Links loaded into the project. Links could make some elements not visible sometimes
eizinmyat
I attached the link so that you can check with your current situation. I hope it helps you.
https://forums.autodesk.com/t5/revit-architecture-forum/floor-not-visible-in-floor-plan-but-only-vis...
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
[email protected]
tranhang13798
yes, even in Coordination and Structural as well. Showing up in 3D is ok.
I even tried in Zoom to fit option but it doesn't work at all.
tranhang13798
I have found your solution before uploading this post. Does not work 😞
RSomppi
The reasons that things don't show up are numerous. Share your file for a direct responce instead of guesses.
